1834 display problem
linhkienbodam
My VX2 display can rotate 1/3 display only. I tested it with other radar antenna from other boats and it runs same situation. What happen with my radar
Thank you
TX Sector blanking was off. I clear display memory and set it to factory default but it till not run well
because you have tested it with other antennas, I would have to say it is something in the display that is bad. You factory cleared it so it shouldn't be related to a setting. I am guessing that it is the main processor board that has a problem. You might want to send that in for repair evaluation.
