my setup is as follows: i have an FCV-1150 with an R509LH transducer as a separate installation and i also have the tzt2 along with the DFF3D with 2 transducers B54 and B45 hooked into the tzt2.
If i install the 165T-PM111LM i have a few questions please:
1- does the low and medium 2KW chirp work on the tzt2 as chirp? if yes, do i have to install any additional black boxes to have it work in chirp?
3-will the accufish and the bottom discrimination still work on the tzt2?
2- if i also have an fcv-1150 installed, can i also connect this 165T-PM111LM at the same time to both the tzt2 and the fcv-1150?
3-will the performance on the FCV-1150 still be great knowing that the FCV-1150 is not Chirp ready?
4-will the accufish and bottom discrimination work on the FCV-1150 if i use the 165T-PM111LM?
5-is the performance better for deep dropping between 300 to 600 meters on the 165T-PM111LM than the R509LH based on your experience. i have no problem marking the bottom but seeing fish at these depths is proving difficult that is why i am asking.
thnx
thnx
