A Anonymous Guest Jul 12, 2017 #1 How do I adjust the clock on my tztouch 14? I have it set to sync time with gps but the clock is off by 20 minutes?
Johnny Electron Administrator Staff member Jul 13, 2017 #2 Does the GPS have a good fix with clear view of the sky? Where are you located?
A Anonymous Guest Jul 13, 2017 #3 ITs a furuno gps, clear view of sky mounted on top of pilot house. located in southern california. The clock has been off since day one for about 3 years now.
Johnny Electron Administrator Staff member Jul 13, 2017 #4 What is the time offset setup for? It should be UTC (minus) 7:00 for your location.
A Anonymous Guest Jul 13, 2017 #5 Pugz I just went thru this too. You have to go into data sources (Inial Setup menu I think?) And set ur gps to be the date/time source.
