I have 2 TZT MFD's where I would like to input 4 analog engine room cameras as per manual using an Axis video encoder. The manual only lists the Axis 241Q which Axis has replaced by model P7214. Axis also makes a less expensive model where the only difference I find is the ability to display 4 streams at 30 fps for the P7212 instead of 15 fps for the P7012. As I don't need the higher fps for monitoring my engine room can I use the P7014?
