TZT9F chart update.
Nube
I recently updated the MM3D charts on the TimeZero Pro computer. Both are logged into my MyTimeZero account and the are set to share the one chart license. After cruising a bit I noticed that the chart on my TZT9F didn’t update. I clicked on the download codes hoping that would do it. No luck. How do I update the chart, hopefully without having to remove it from my NavPod.
Thank you for any advice.
The only way to update charts on the microSD card in a TZT9F is to remove the card and take it to a Windows computer to replace/add any charts. If there is more than one TZT3 display in the system, this will need to be done for all.
Mr Reaper,
Thank you for the reply. I kind had the feeling that is what you were going to say. Opening up those nag pods isn’t a pleasant experience. For the TZT9F I go to the same website that I did my MM3D charts on.
On a sidebar, to your knowledge will you ever be able to use TZ Maps on TZT3.
Thank you.
Yes, it's the same place you get your MM3D charts from.
Sorry, I can't comment on any future developments.
