transducer for best bottom detail
hori
Hello, I`m looking at getting a 588 and want a transducer that would show me the best bottom detail in 30 to 650 ft. thanks
Snips,
thanks for the reply, I was told the B-260 is a good match. Can someone educate me on the broadband side of these transducers, does that give the increase of bottom detail? And would a broadband transducer matched to a broadband sounder with capabilities to adjust frequencies give greater clarity and bottom profile detail?
Hori,
Generally the term "broadband" means that a transducer should work over a broader spectrum of frequencies. In theory, they should work equally well over that wider spectrum of frequencies, but from testing we found they do not. All transducers have a sweet spot that they like to resonate at. We tried using broadband transducers with the 585 and found that the HF side worked OK but there was a noticeable performance lost on the LF side. We found the LF side of the broadband transducer liked to resonate at 42Khz, the but 585 was transmitting at 50Khz. For this reason we don't recommend using any broadband transducer with our fixed frequency (628/588) sounders.
