Please confirm or negate compatibility with DFF1-UHD to Airmar B175M 0 degree and/or SS175M 0 degree. And why or why not? All connected to a TZT14 MFD,
This has been asked before, officially the transducers for the DFF1-UHD are the following:
The *265LH varieties of CHIRP Broadband Transducers
The *275LHW varieties of the CHIRP Broadband Transducers
However, our resident sonar expert has said in the past,
"The UHD sounder was designed to use both HF and LF channels. If you are connecting only the LF side we advise you to add a 100 ohm-10 watt loading resistor across the HF side (pins 1 & 4). Note when you are using only one frequency, neither ACCU_FISH or the Bottom Discrimination Mode are available. The B-175 will not appear in the sounders transducer set-up menu so you will need to select a B-275. Do not connect the Orange TID wire."
See: viewtopic.php?f=7&t=6457&p=25689&hilit=uhd+175#p25689
That being said, you can only use the B175L or H/HW, the frequency range of the *175M is not supported.
