Quitsa
A friend who is usually knowledgeable is trying to persuade me to use a 12kW unit on my boat and not the 25kW I was planning to get. His argument is that if the radar is mounted relatively low to the water -- about 9-10 feet in my case, the extra power output of the 25kW causes more spurious returns and actually the 12kW or even 6kW will be a better performer except for extreme ranges and spotting thunderstorms.
Is this a valid point? I will have a six foot array and my main objective is to have the best capability to spot birds at 4-6+ mile range. The conventional wisdom says to get the most power possible to see birds and use the 25kW. I have used 25kW radars many times but always on boats that are bigger than mine where the array was mounted 10 feet or more higher off the water. My old boat had a 6kW 4 foot array mounted about 9 feet off the water and it was quite good at showing birds out to 4 or 5 miles if it wasn't too rough. So of course I assumed more is better and was going to a 25kW until my friend gave me some doubts.
