Yamaha Gateway - Engines on Display Reversed
Gufharbors1
I have twin 2020 Yamaha F200's connected to my N2K backbone with a Yamaha gateway device from the Yamaha bus bar. My new TZT3 can read the engine data and I appear to be getting normal readings. However, the port motor shows on the right side and starboard on the left on the display. I called Yamaha and they said this is a common issue, but has to be corrected on the MFD side. I have thus far have been able to find a way to adjust anything that shows on the Yamaha engine display (It seems like a fixed section) and I was not able to see a way to swap the engines in the initial setup menu on my TZT. I should mention that the 2 Yamaha 6Y8 tachometer gauges read the correct motor and they also feed from the Yamaha bus bar. So far I love my new TZ's they are a big upgrade from my old VX2 system. Would love them even more if I can diagnose and correct this issue. Thanks in advance!
On the TZ3,
1. Double tap the gauges to get the "Choice of the Config Type" menu
2. Scroll down and tap "edit page"
3. Tap and drag the gauges around the page in the orientation you want.
4. Tap the gauges again, and tap "end edit."
Hope that helps,
- Maggy
Good morning Gufharbors, did you resolve your issue with the twin yamaha set up , I have a tzt3 and I'm trying to figure out how to set it up on my furuno, no luck for now
