Xl 13 video input?
e_deher
Does anyone know how to get a video input to the 13 xl? I have a camera with hdmi that I would like to connect. Thanks
That is very disappointing....you would think that a $3700 screen would have a video input ready to go...will it accept video in through the usb connection?
Video isn't by USB. It is always recommended to check features of products before purchase because maybe the 16x would have been the better choice for your needs. The published features are what is offered and available.
The 16 would not work for my application. I needed two screens and hardly had space for the two 13s. What about the multi port? Seems there is some $120 cable (again very disappointed) that will take a rca video plug? I guess I could use a converter to go from hdmi to rca if that is the case.
Yes, HDMI could be converted to RCA composite as you explain. A suitable device might be hard to find. It would display on the unit for which you connect it into. The previously suggestion would allow either display to see the video, would not require a converter or optional multi-cable.
Yes but I also don't have any other ports on my ethernet hub. Maybe if I could return my 5 port furuno ethernet hub and get a 8 or 10 port ethernet hub from gigabyte I would be able to do that. I don't know if they will accept the return though. I will have to check
