Wind source changed alarm
I have a TZ BB system and since installation I get an alarm from the autopilot that the wind source has changed and have to hit the large button to silence it. I have both the 711C and 700 installed and I have the FI5001 Wind Sensor with no other wind sensor.
I recommend you check what wind items you have shown in the pilot setup under sensor selection - Wind. You should have the FI501 as your primary source on line #1 with the other two lines having dashed lines. It sounds like someone has put some other sources and it is switching during periods that you are having wind loss.
