Which uhd transducer
Hi there
My current configuration is navnet 3D dual.connected dff3 to r209 and dff1 to b164
I just bought a single tzt 2 15 and wanted to upgrade to chirp .
R209 has a custom fiberglass cavity so I can take it out and replace with a new r509
.as I understand correctly I need uhd black box so I can run chirp however when I read the specs the output of the uhd is 1.2 kw.my old dff 3 has an output of 2 to 3 kw .
Is furuno releasing a big uhd just like the dff 3 to power the big chirp ducers?
Is installing the r509 in the uhd knowing the max output of the uhd 1.2kw is not utilizing the full Potential of the r509?
I fish between 30m to 800m for swords
Another question.how many transducer I can run in one tzt2 and what is the setup if I want to add the new 3D wasp with the uhd to single tzt2 .do I need a second display or only hub 101.
Thank you
Fbaksa,
Could you use the R509LH with the DFF1-UHD, yes you could. The better match would be the R509LH paired with FCV-1900B. The other alternative would be to use the DFF3 with the R509LH.
ok great ! how about connecting connecting 2 transducers to one tzt2 ..is it possible ..one regular 1kw 512 tid hooks directly to the tzt2 and the def3 with the r509 via ethernet ? r509 is medium low frequency but the 512 will be set to High frequency .
Fbaksa,
The TZT2 can only display one sounder module at a time. You won't be able to display the high frequency from the internal module and the low frequency from the external.
Snips":29b6pvgd said:
Fbaksa,
What if there are 2 tzt2 units in the system?
Syrupdawg,
Each MFD can display what sounder module is selected.
