Vector Chart Contour Settings TZT vs. TZT2
MarMax
Why are the settings for vector chart contours different between the TZT9 and the TZTL12F? The shallow, safety and deep contours are like 3.0, 6.0, 9.0 for the TZT9 and 3.3, 6.6, 9.8 etc for the TZTL12F. Not a big difference, but enough so that the same map at the same location at the same scale is slightly different between the displays.
The bottom line is they are different systems with completely different operating systems. It is totally amazing that the have allowed them to work together so well. The TZT2 in the background appears to be working everything in Metric the best I can tell. I find that even when expressed in feet, the selections are using some sort of conversion to round to the nearest meter. When I took two units (TZT14 and TZTL12F) and set them up in settings as close as possible the contour lines did match up. a few of the spot settings were different but also at different locations on the map and correct. The screen sizes of each unit can also cause some difference because of map scaling. I am not really finding this to be any concerning problem.
