Upgrading from go xse to a TZT12F. I was wondering if the old 3 in 1 transducer on my transom can be utilized in combination with the through hull I have purchased?
The TZT3 has one internal sounder so if you are keeping it busy with the thru-hull; it won't be able to connect to another transducer regardless of type.
Thanks for the reply. Will it be able to read the down or side imaging data from that transducer if it is connected or is that transducer not supported?
At this time the only side imaging is via the DFF3D multi-beam sonar add on. It wouldn't be able to use that transducer for that funcrtion but depending on the impedance it might work for down imaging when properly wired. It is unlikely to work well if it does. You might want to let that one go with the simrad.
