H hanapaahi Guest Jun 27, 2020 #1 I'm upgrading from a 582 to 588. can I use the same through hull transducer for the upgrade. :furuno
S Snips Guest Jun 27, 2020 #2 Hanapaahi, The 582 used an 8-pin transducer plug so you will need the 8 to 10-pin adapter (air-033-204) so it will connect to the FCV588. Snips
