Updating Charts Error - MFDBB
Clemson101
I’m the new owner of a 2012 Fleming with a MFDBB, 2 MFD12’s and 1 MFD8. I’m attempting to update the charts using the “NavNet 3D Chart Installation Guide v3.0” and “NavNet 3D Chart & Data Management v1.0” documents. I’m receiving errors when I attempt to follow the steps for “Chart Updates”. I insert a blank 2GB SD card into the MFDBB card reader slot and navigate to “Request Update File”. The system recognizes there is a SD Card in the reader and when I click OK to request update I receive an error message. I’ve tried different SD Cards, formatted SD Cards, unformatted SD Cards (the instructions say the NavNet MFD will format the SD Card) and still receive an error message.
Also I cannot upload any routes using SD Cards containing GPX routes. I receive an error message that there are no routes on the SD Card even though there are.
I have the Sytem ID for the NavNet 3D system and serial #’s and product registration #’s for all the MFD’s.
Please advise on any additional instructions or registration process I may need to complete to update my charts. Thank you.
The request update file was used in the past when the system updates were active on the NavNet3D's, however since the units will not have any more software updates that function is no longer used.
Please go to MENU -> My NavNet and provide the Software version you have on each unit. This will allow me to let you know what maximum size SD card (for the MFD8/12) and USB memory stick (for the MFDBB) you can use.
Briefly, you download and extract the newest charts and then extract them. For the MFDBB you copy the extracted files onto a USB memory stick and load them through the USB port on the MFDBB box itself, you DO NOT use the SD card slot.
For the MFD8/12 do it the same way EXCEPT copy the chart files onto a SD card, the MFD8/12 load charts via the SD card slot.
Once again please give me the sw versions of all 4 units then I can fill in the details on the maximum size SD card and USB thumb drive you can use.
Thank you.
The BB software version is 1950064-02.08
The other 3 MFD’s all have the same software version - 1950055-02.07
And all 3 of the other MFD are 12’s (not one of them being an 8 I indicated earlier).
Thanks again.
Okay, great. You can use up to a 16GB USB memory stick for the MFDBB charts and up to a 16GB SD card for the MFD8/12's. I can send you an email with the charts you have purchased and the free ones you want to update. I'll PM you and you can give me the SYSTEM ID found in MENU -> My NavNet -> System ID.
