Update 3.01
BReceski
So right now I have the down loaded files in a folder on my desk top. This is what I seen a regular folder after the download.The folderol desktop is named: NNTZT3+v3+01+Software. Inside the folderI see the following:
autoupdateconfig.txt
chartdemopath.txt
CopyItem
FEC
IDCODE.SYS
MANUAL.BIN
QB_FORCE_EXIT
Can you kind of walk me through what I need to do to get this onto usb drive . Not sure how to get these opened and onto the drive. Sorry for not being up on this stuff.
Not sure if these need unzipped? This was done on a mac.
Thank You
Bill
Good morning,
below are links to a couple resources below that may be helpful.
Link to update instructions:
https://www.furunousa.com/-/media/sites ... ctions.pdf
This link will contain the instructions on where to find the directions on how to back up your data and it will give you directions on how to transfer the files you see to a USB stick.
Also, in order to try and answer your question, you will not open those files you see. You will simply just copy and past all of them on to the root of the USB stick. meaning that when you open the USB stick the first thing you should see are all these files. NOT in a folder of any kind.
A link to the factory reset instructions that you will need to preform:
Hope this helps!
chartdemopath.txt
CopyItem
FEC
IDCODE.SYS
MANUAL.BIN
QB_FORCE_EXIT
Thank You
Bill
