D
DTrol
What type/size of wire do you suggest I use to extend the blue and white conductors of the multi-cable and what type of connection (soldered?)
What size is each conductor on the muticable (other than very small)?
Do you have any type of quick-connect you can recommend which would allow me to disconnect and remove the plotter without having to undo hard wired connections of the multi-cable? I am only using the blue and white conductors.
Thx.
Thx.
