TZtouch2 - CZone DIP switch conflict
e.ruscigno
Hello,
The problem arises if you have two or more TZtouch2 (enabled to CZone) on the same NMEA2000.
Upgrading to 6.21 saving and restoring the TZtouch2 configuration does not create any problems, and the CZone DIPs switch remain as before.
Unpredictably and randomly, a DIP switch conflict appears on the native CZone displays that does not appear if the two TZtouches2 are turned off.
The problem has been highlighted several times without any change to the CZone or TZtouch2 configuration. The problem manifested itself "autonomously" by turning on the two TZtouch2.
Disconnecting the two TZtouches2 from NMEA2000 and reconnecting them one at a time makes it clear that both have changed their CZone DIPs to 00000011, which causes the DIP switch to conflict highlighted by the native CZone displays.
The previous TZtouch2 version has never produced this issue.
The TZtouch2 version 6.21 has produced several times the problem i am reporting.
Reconfiguring TZtouch2 in navigation can be difficult and dangerous.
To eliminate the risk I physically separated the two NMEA2000 networks...no CZone display for TZtouch2.
Best Regards,
Enzo.
Thanks for the information. It sounds like good information that should be investigated by your distributor. You might consider trying the newest software v6.26 to see if that changes anything for you.
