The 526TID-LTD is the Bronze Version of the B164. It's a 10-Pin, 1kW 50/200kHz Transducer and it will work with TZT3. Just be sure to use the 10-Pin to 12-Pin Transducer Adapter Cable that is provided with every MFD, and then select the B260 Transducer in the Transducer Setup Menu. The you should be good to go..!
