New screen
Hello everyone
I have a 2005 Carver with original electronic equipment. Last summer we ordered one new TZTL15F, but our rep says he never received it. We opted for a "Demo Model" from another rep, used for a few years. It ended up to be a 2015 model. It came with the 08.01 version software on it and almost everything seems to run finally.
The only issue that remains is that I can't get the "HEADING" value from my old Autopilot (NAV Pilot 500) to the new display. The Autopilot works.
I was given a data conversion cable (IF-NMEA2K2) to make the connection. These are the colour of wires I have connected (left to right) in TB7 in the old Autopilot processor unit: light-blue/green light-blue/yellow pink pink/black
position 3 and 4 already have wires in it from the VHF unit (FM3000)
When I look in the Data sources list, I see the IF-NMEA2K2, but no numbers are showing up.
On the other hand I'm thinking that it could be a setting somewhere that the rep made because it was used as a DEMO unit.
Can anybody verify the wire connections, as I was given 3 different versions from my rep.
Thank you so much.
I realized that I might have missed some important information.
The mentioned colour wires are probably unique to my connection cable. In the manual that came with the cable there is a conversion table to probably a more generic colour scheme of wires:
light-blue/green blue TD-B
light-blue/yellow white TD-A
pink yellow RD-H
pink/black green RD-C
This is what I connected from left to right.
I hope this helps.
Thank you so much.
pink yellow RD-H
I hope this helps.
