TZTL12F whit FIP 460.
Kjelli
Hei.
I Have the NavNet TZtouch2 Chart Plotter and I have been looking for a camera to use. I have purches a Axis whit POE but that needs at least 44 Volt and I have 12 V in the boat.
So I have been looking at the FIP 460 and was wondering if it will work whit my plotter.
What should I look at the softwear version maybe in the plotter and if there is anything else?
Thankt you in advance.
Kjelli.
The FIP460 while is designed for the TZTXL, has been shown to work well on the TZTL12F instead of an Axis Camera. You would need to manually assign the IP address and configure the camera. The existing software shouldn't matter but it is always recommended to run the newest software for your MFD.
I just had one issue now and it is that the camera interfer whit the VHF. It makes static and it goes away when i disconnect the camera. Can it be the white connector were the cat 6 cable goes and the plug to 12V ? Is there any way to sheel this or do anyone has any idea on what the problem is and what I need to do?
Kjelli.
