RightRigger
Hello ! New to the forum and of course hoping for some help. I cannot get a video stream on a new install on my boat that includes a 16" TzT3 and a M300c . I have worked with both Furuno and FLIR support with several phone calls to each and the outcome seems to now be a request to send the the FLIR cam in to Furuno for programming. Has anyone out there experienced the decoding error that I receive after running through the setup for the IP camera ? I have done the following :
1.) Gone through the laptop setup of the IP assignment as required by logging in directly to the camera and the JCU - the result is the camera video comes up on the laptop and the camera can be controlled via the laptop ( After installing the camera through the FLIR installation process on the TZT3, I can control the camera with all three options : Laptop, JCU ,and TZT3 but just a black screen on the TZT3 with this occasional video decoding error comes up instead of a video stream ).
2.) I have updated the FLIR firmware via the same laptop
3.) Confirmed the TZT3 software is version 2
4.) Bypassed the network hub and ran the cam wire directly into the TZT3 - Still had camera control but only a black screen.
5.) Performed a factory reset through the Service tab.
6.) I ran through the FLIR install process and reset to defaults more than I can remember at this point
7.) Tried every FLIR option as well as the M300 with no progress.
Hope this was enough info and definitely appreciate any other input to this very frustrating scenario.
Thank you in advance !
