Is there an internal buzzer/beeper? If yes how do I get it to work with anchor watch?
I have noticed the swipe up feature does not work very well from the lower center- up but it works very well if I swipe up from the lower right-up. Is this normal? I do have the fusion media bar on also maybe it is interferring.
I have noticed the fusion bass, mid and treble controls reset to 0 every time after leaving that screen. Glitch? I have the BB-100
How much performance will I gain if I add the DFF-uhd over using the internal finder? I have the B265LH ducer. I normally fish in 60 to 300 feet but want to do more bottom dropping in deeper water.
HDMI in and out, does a HDMI touch screen control the Furuno or does the Furuno control the touch screen? Or both? Will it also require a USB connection?
What is the best way to control the Furuno that is on the bridge from the lower salon while viewing the Furuno on a TV? Is there a controller that will work through the ethernet network?
Touchpad through usb
Mouse through USB?
Encoder?
MCU ?
Tablet through the app?
Mouse through USB?
Encoder?
MCU ?
