TZT3 nmea to a gp 1971
Yes, the TZT3 and GP1971F can be on the same NMEA 2000 bus. The GP1971F could share any good GPS data, transducer depth, water temp etc. If the transducer is on the TZT3, then it could send that depth/temp over to the GP1971F. While the GP1971F is not a Navnet, it will share basic NMEA 2000 data. You will not be able to use any TZT3 radar or sounder pictures on the GP1871F or see the GP1871F sounder on the TZT3. The GP1971F is not an Ethernet device like another Navnet display.
No. They each would keep their own dataset. It is possible to use media to transfer points from one to the other using the GPX data format.
rodneymeyers":38xzcqzt said:
Can you connect the tzt3 to the gp1971? If so what data will they share?
The better question is what do you want to share between the two? If we made a list, it'd look something like this:
Code:
126992, 127250, 127251, 127257, 127258, 128259, 128267, 128275, 129025, 129026, 129029, 129033, 129283, 129284, 129285, 130306, 130310, 130312, 130316
If we look at the combined output lists of either device. Some of it is dynamic (e.g. 129025/26) and some of it intermittent (129283/84).
I recommend If you have a specific data set you're interested in sharing, print out these pages of the brochures and compare the inputs and outputs of the NMEA2000.
View attachment navnet_tzt3_brochure-final-lr.pdf
View attachment gp1x71f_brochure.pdf
Otherwise, just make sure you have a few SD Cards and USB Drives in your pocket before taking off on a trip :) :D
Hope this helps, :sail
- Maggy
