Hi all!
I've just purchased an IMG 54'CC and am in the phase of ordering my equipment! After considerable research and many many excellent recommendations I've chosen to go with a full Furuno setup. I normally fish for yellowfin in very deep waters (8k feet+), swordfish, grouper etc in about (2-3k feet) and also fish extremely shallow waters (150ft) for snappers, jacks etc. The list below is the setup I've decided to go with, it would be greatly appreciated if anyone could let me know if I'm heading in the right direction or should add/remove anything!
1. 3x TZT 24X
2. DRS25A X-Class 6'
3. DFF-3D
4. DFF3-UHD
5. 200WX
6. 711C nav pilot
7. SCX20
I want to use a 5kw transducer for the finder so it can cover both depth ranges comfortably, is this the right idea? I'm under the impression that if I install the BT-5 this would be fine.
The boat will be running Quad 600s and the boat manufacturer told me I'd have to run the Mercury autopilot system which I wasn't even aware existed, is the 711C compatible as that would be much preferred!
I'm installing a Flir M332 as well. Will this be compatible with the MFDs?
Thanks!
1. 3x TZT 24X
3. DFF-3D
4. DFF3-UHD
5. 200WX
6. 711C nav pilot
7. SCX20
Thanks!
