stevemitchell
I have two brand new TZT2 12" displays I added to my flybridge about 2 months ago. They are powered by a dedicated circuit that has both the TZTs, DRS4D-NXT, and Furuno switch. I have both TZTs wired per the manual, with ferrite as close as possible to the power connector, and separate ground wire. This circuit has been in place for many years, and powered older vx2 series Furuno equipment which was super power hungry compared to the TZT+DRS.
I have a considerable NMEA 2000 network along with a lot of other things which you can see here https://sailbits.com/content/images/2019/03/Rendezvous-Network-2.png
My house bank powers all of these devices at 12V and is also responsible for my windlass. This setup has been working on this boat fine for 30 years prior to me purchasing it. It would be more ideal to have a separate battery or battery bank for the windlass, but I see no reason to change it at this time.
While using the windlass, voltages can drop, especially if I have been at anchor, and the TZT2's reboot almost every time. Not a single other device on the network, including other Furuno products, Raymarine Axiom, B&G, NMEA 2000 powered devices, reboots - only the TZT2s.
After a lot of troubleshooting, it appears this is related to the voltage drop, and it is surprising to me that the TZTs are so vulnerable to this while everything else is not. I have since added a DC-to-DC isolated power converter from Victron to ensure that the circuit at the flybridge always gets 12V and that has solved the problem for now.
Is this a known issue with the TZT2s?
