TZT2 TRANSDUCER BEST PERFORMANCE SETTINGS
bgur
I am using Navnet TZT 2 12 and airmar p66 transducer. I am trolling in depts of less than 100m . İs this equipment sufficient for acheiving best information ? Secondly I cannot see the tracing of my rig on the screen . I would be pleased if you kindly send me the accurate settings of the device.
You might contact the distributor or your installer about your system configuration. Your distributor is:
OZSAY DENIZ ELEKTRONIGI A.S.
Guzelyali Mah. Ibrahim Hakki Cad., No.46 Pendik, 34903 Istanbul, Turkey
Phone +90 216-493-3610
Fax +90 216-493-0306
URL http://www.ozsay.com/
E-mail info@ozsay.com
You are outside Furuno USA's sales and support area and we are not familiar with the waters which you operate. Generally a 600 watt transducer should be suitable for 100m.
Let me give a fisherman's answer. When you are trolling, most likely your line is at a 45 degree or greater angle. I don't know the beam angle of the P66, but I doubt it is greater than 25 degrees. You would therefore not bee able to see the tracing of your rig.
You could confirm that what i propose is indeed what is happening by lowering your rig to 150m depth while not moving, confirm you can see your rig, begin trolling & watch as your rig moves outside the sweep angle of the P66 & becomes unviawble
The beam angle of a P-66 is 45 degrees on 50Khz and 12 on 200Khz.
