I have a TZT14, PSU012(for DRS4A), DFF1-UHD, FA-30 AIS and hub101. I have been having current draw issues with the system turned off and I have tracked the draw of each component. I listed the issues I found with each component. My question, is this normal? If not, any suggestions on what to do to fix my current draw issue. Right now, with the TZT14 power off I am drawing about 4.1amps. I thought everything powered off would maybe be max lass than 1 amp.
1) PSU012 draws 3.25 amps with everything powered off
2) FA-30 0.75 amp with everything off.
3) DFF1-UHD not turning off transducer when I power down the TZT14, I have to cycle the power to get it to turn off.
Do I need to isolate these systems and have a switch for each when not in use? Appreciate any suggestions and comments on what you feel is normal. I have to make a change before I replace my batteries.
