TZT12LF weather page and charts update
anthony
Hi
I have connected yesterday to wi-fi with my TZT12LF and tried to get weather info , but i can not get to weather page.
I am not sure is this feature supported in my device?
I tried to follow operation manual but still could not figure out how to get to weather page?
Software version is 2.0.
Another question is it possible and how to do charts update?
Thank you
That is some seriously old software. The weather service might have changed something over all this time. I highly recommend you update the unit to current software (v6.26).
Go to our website (www.FurunoUSA.com), go to the product page (TZTL12F), Click on "View Support/Tech info", Click on "Software", Download 6.21 software and the instructions, follow instructions, download 6.26 app update and instructions, follow instructions, and done.
hi
In my system i have dff3d, b260 and pg 700.
Could you please advice do i have to do updates with this devices connected or disconnected while doing updates?
Does it make any diference?
Thank you
We recommend you disconnect the NMEA2K drop cable and network cable to the unit when doing the OS update for TZT2, just to make sure nothing unusual happens with the settings of your sensors. If you are doing the "all sensors update" for TZT2, you'll have to keep everything connected because you are updating your sensors.
Hi Kicker thanks for reply
1.Just to make clear , does this means when doing OS update with micro SD to 6.21 - all should be disconected , and later when using USB flash drive for 6.21 and 6.26 i have to connect everithing to the TZT12F?
2.since i already did update first time with sensors disconected can i just repeat process even my system is already 6.26?
Thank you
If you're just doing 6.21 and 6.26, I would disconnect the NMEA2K backbone cable and network cable from the back of the units and keep it disconnected till you do the master reset.
Thank you
I am not sure what you are asking on question #2, if you are already on 6.26, you are on the latest version of software.
Hi
I did software update from 2.0 over 6.21 to 6.26 and i think everithing went ok.
My concerne is did i have to have all sensors connected( b260 , dff3d , pg700) at some point during update process and if i did can i repeat process with sensors connected?
No you don't have to them connected while doing 6.21 for 6.26. We encourage you not to connect everything just to prevent any stalls in the updating process of the TZT2.
You wouldn't do a software update on the transducer, you update the sounder software and if you update to 6.26, you'll have the latest update for the TZT2 internal sounder.
1.04 is the latest for DFF3D, you can check the software version on the [sensor list] of the TZT2.
