G
Gyda
I´ve just installed my new TZ14, and was going to update the software to V5. The instructions to upgrade give information on how to make a bootable TZT program card using the TZ14. Following the instruction led through the success making of the card, but after I pressed OK after the message “Format Success” showed up, nothing happened.
I removed the card form the slot, but still nothing happened. Pressing Home button lead to nothing. I then went through the process once more remaking the card, which went ok, and for the second time the message “Format Success” showed up. I pressed OK, with the same result as the firs time.
There was no way to get out of the menu with the USB test tab. I tried all other menu alternatives, the Home button and the ON/OFF button without any success.
At the end I had no other opportunity than hold down the ON/OFF button for about 10 sek and the TZ14 shuted down. Not a very good start with a new and long sought after device…
