Transom Mount Transducer for CHIRP
I just purchased a DFF1 UHD and am looking for either a transom mount or low profile thru hull mount transducer. I know that there are a few out there that are made by AIrmar(B175H/M/L,TM265LH/LM). Would either of these be compatible with the DFF1-UHD. I am running a 12"NN3D MFD. I am upgrading from the standard DFF1. I currently have a low profile 50/200KW B164/12degree transducer. Any input will be appreciated.
Thanks,
Brannon
Wyattbrannon,
From our testing we have found that the UHD is a little more susceptible to turbulence on the LF side. That being said we are recommending either the can (CM) or fairing (B) mounted 265LH transducers because the face of the transducer will be a little deeper in the water and away of the hull of the vessel. However you can use the TM-265LH if you wish. Because the UHD has both ACCU-FISH and Bottom Discrimination the flush mounted 175 transducers are not in it's data base.
