I have a Furuno 1971F chart plotter/sounder with an airmar B164 1kw transducer. I am setting up the transducer and I do not see the B164 on the set up list. What transducer should I select from the list?
If you have a version of B164 that's a Tilted Element Transducer, you then can also select: 525T-LTD/12 or 525T-LTD/20 as this transducer is using the same B164 housing.
If you have a version of B164 that's a Tilted Element Transducer that you have, you can select: 525T-LTD/12 or 525T-LTD/20 that is same as the B164 housing transducer.
