Hi all,
I have two TZT2 MFDs that I updated to the latest firmware.
After the update, the Master MFD does not send route/course information to the autopilot when the Slave MFD is ON. If the Slave is OFF, the Master talks to the autopilot without a problem.
On the other hand, the Slave talks to the autopilot fine regardless if the Master is ON or OFF.
Does anyone know why this might be happening?
More info:
Is it possible this problem is IP address related?
Before the update, the Master had IP addresses 172.252.25.1 and the slave 171.252.25.2.
After the update: the Master has IP 172.31.252.2 (host name MF252002) while the Slave has 172.31.252.1 (MF252001).
Thank you.
More info:
Thank you.
