The ST-02MSB is a simple speed and temp sensor designed to connect up to sounders MJ connection like the DFF3 has. It is not a transducer. No it can not be wired to the TZTL12 as such. While if the TZTL12f has a transducer, it would be possible to use a junction box and wire the temp into the built in sounder replacing the temp sensor used in the transducer. I would recommend you discuss your needs directly with tech support.
