sonar
  • Thread starter Thread starter pichot
P
pichot
Hello what are all the settings of the sounder between 5 meters and 10 meters depths merçi
Setting gain speed scrolling transmission rate shift gain etc. in shallow water between 5 and 10 meters of bottoms
Default setting usually work just fine. Depending on the transducer you are using will determine if Bottom Discrimination, RezBoost, and Accufish will function. What transducer are you using?
If you are having an issue can you please post a screen shot or a description of the problem.?
Where is your boat? Perhaps one of our agents needs to take a look at your set up. We have had no issues reported with 5.02 upgrade.
