Tasty Waves
I have a nn3d that came with the 2008 GW 306 Bimini I just purchased three weeks ago. Initially when turning on the master both units would power up. When the units were about halfway through powering up the slave would shut off. You would then use the power button on that unit dnd turn it back on. After that everything worked fine. Today the slave unit will not power up either through the master nor through its own power button. There is power coming through the power cord.
Is there an internal fuse on the unit? What else can I check?
