Single Mount Side Scan Sonar
scott diego
I have looked diligently, I am a dedicated pelagic fish fisherman. I have seen the typical ram mounted side scan systems. Is there a single mount system that is available now that has the side scan technology that does not require a ram?
All help is greatly appreciated.
Scott
Scott Diego,
Thank you for your inquiry. Furuno does offer a true multi-beam black box echo sounder capable of displaying side scan imagery (as well as several other views/displays) You might be interested in the DFF3D https://furunousa.com/en/products/dff3d. It is fully compatible with either the NavNet TZTouch or TZtouch2 MFD's. It utilizes a fixed mount 165khx multi element transducer capable of up to a super wide 120 degree beam angle. There are several different transducer options available, including transom mounted https://furunousa.com/en/products/165t-tm54 and thru hull https://furunousa.com/en/products/165t-b54
