Wdeertz
I have a TXTBBX as a chart master on my network. My second MFD is a TXT2BB (chart master not turned on). I also have Timezero on a computer connected to the Navnet network which I recently upgraded from TZ Nav to TZ Pro.
When I start up the TZTBBX only I get a message “SID not found TL…… (3 runs/30)”. The SID is the number linked to the TZT2BB as that was my chart master prior to upgrading to the TZTBBX. If I start both TZTBBX and TZT2BB at the same time I don’t get the warning message. This warning message first started appearing after I upgraded to TZ Pro so not sure if this is a TZ associations issue.
When I look at my TZ page it shows both the TZTBBX and TZT2BB SID’s. I had both MFD’s sign into TZ cloud but have since turned off sync’ing from the TZT2BB since it’s no longer the chart master (not sure if this is correct). When I look on the TZT2BB synchronization it shows the TZT2BB as the cloud master, shouldn’t this be the TZTBBX?
Please advise, if this is a TZ licensing issue please let me know and I’ll contact them to get sorted. Thanks
