I plan to add a SCX20 next season. Is it possible to send the data to the FCV 1150 via the TZT3 multi cable on NMEA 0183? Or can the 1150 get the data via one of the Ethernet connections?
You can send heading via the MFD but what you really want, Heaving, isn't available via the MFD 0183 port. The best method would be to use the IF-NMEA2k2 converter from the shared SCX20 NMEA 2000 bus to the FCV1150 to get everything you need.
