Quitsa
After applying the 3.701 software upgrade, my TZT3 16s have taken to periodically freezing. The actions that seem most likely to trigger seem to be linked to the data boxes on the left side. For example, switching the displayed data box between "data" and "fishfinder" or "route" or editing the content of the data boxes will cause the entire screen to freeze. The sounder display will stop moving, the boat icon will stop on the chart, and the data stops updating. Other touch functions will work sometimes such as the Home button and switching what is active or the shutdown menu that comes up when the power button is pressed. The only way to get out of this state is to shutdown and restart the unit. It does not happen consistently and does not seem to correlate to how long the unit has been running so I doubt there is an overheating issue. In addition, my helm behind the units is well ventilated with a cooling fan.
I tried doing a hard reset back to factory default and reinstalling the software from a USB stick and redoing my settings from scratch rather than uploading saved settings. It did not eliminate the problem. I called tech support in Camas and the fellow suggested doing a hard reset on the internal sounder, which I also tried without success.
Has anyone else seen this issue? Sure seems like a bug.
