Recovery from OS crash
Status
Not open for further replies.
I have had to completely re-install MaxSea Explorer after my OS crashed. Is it possible to extract my track data from a 'Tracks2.mdf' file I backed up before the crash ? :questions
It is best to keep copies of your info using the "Backup Collection" feature. In the case where you only have the track2.mfd file, you might be able to use it but it can be tricky. The file could be input manually into the correct directory on the PC, but handling the file manually can cause a permission issue; especially if you move it from one computer to another. If you want to try it; close MaxSea and go to "\Programdata\MaxSeaInt\Data" and make a backup copy of your existing track2.mfd file. Then take your old track file and overwrite the normal/current one and then try opening MaxSea and see if it works for you. If it doesn't, restore your original copy and write it up as a lesson learned to conduct regular backups.
Thanks Johnny, I tried what you suggested, but it did'nt work. It may be because I had to enter a new unlock code for MSTZ. Unfortunately, the 'Backup Collection' function wasn't available in the version I was using at the time.
Do you by any chance know the Maxsea SQL Server name and passwords etc ? I may be able to access the data via an Excel data connection or direct.
Only MaxSea can give the internal passwords. I don't think there is much chance of that !
Status
