Hello,
I have an RDP-149 being used as a radar repeater, slave to an RDP-150. The RDP-150 is not having an issue, but when the RDP-149 is energized, the radar returns start out as one would expect, crystal clear, exactly what you want to see. Then after 15 minutes or so, the image quality starts to degrade around the center of the vessel. Finally, you start to see 95% returns across the scope, almost like your gain was cranked and all the suppression turned off. This follows the sweep intermittently for a few minutes. During this time, you can adjust for the excess noise, but then when things go back to normal after a few minutes, you're over compensated in the wrong direction. Any idea what is going on here? Again, the primary display is having no issue which seems to rule out the antenna or outside interference?
Thanks,
Brennan
Thanks,
Brennan
