RD30 doesn’t start
JManu
Hi, I’ve just disconnected my cockpit RD30 for cleaning and just after that and connecting back it appeared that no switching on was possible. I checked current is ok in the cable, no problem of external fuse. Is that possible that connecting the cable to the AUX plug could damage the device ?
Are there some internal fuse that should be replaced ?
What could I do ? Thanks for advice.
No, you will not damage the unit by putting the IN/OUT cable on the AUX port, they are connected internally. There are no fuses internally. Check the pins (for pwr) on the connector jack to make sure they are not bent or broken-off.
