Hi,
I have a rdp-139 with an rsb-0071 scanner. When begin to transmit, the radar works correcty, but after about 1/2 hour of run time, the targets on the display begin to rotate around the screen a couple of degrees for every rotation of the scanner. after the unit is shut off for a while, the radar can be restarted and will work correctly again for another short period of time.
I believe that the motor for the scanner has a pulse generator an i am wondering if this is beginning to malfunction, or if it is more common for the display to not read the pulses correctly once it warms up. some input would be greatly appreciated. Thanks!
