The 19" dome for the radar has 4 screws on the base. If I release the screws, will the cover come apart or is there an additional trick to separate the cover from the base?
Reason I ask, so I can plug in a data line. I am concerned that I will have an issue getting the connection line up the mast conduit and I will need to proved power and data in separate cables. Thank you for your help with this query.
