PUMPHRP35-12 pump
pkelly
I have installed a 711C autopilot and will need to use a PUMPHRP35-12 pump because of the steering cylinders displacement. The existing HRP12-12 pump causes the autopilot to give an alarm for slow steering. The cylinders are Capilano 175-11s.
Having a pump too small or too large is a problem for autopilots. The pump must be established correctly. Ideally, you are looking for a 10 second hard over to hard over time. The PUMPHRP35-12 is nice because it has a flow rate adjustment that allows more flexibility to get that perfect timing.
