PSU005 setting
linhkienbodam
Hi,
I changed a magnetron on my Furuno 1954C radar. It is said that I must set SW1 switch in PSU005 power supply upward for adjusting a correct signal and reset SW1 switch downward when we ended. I finished and it seems my radar catch a targets very well but why the signal of upward possition is double stronger thand downward's (all range)? Can I use SW1 upward for my radar? Thank you
No, that is only for when the adjustment is being made. The radar should be fully optimized and then optimized in the software off shore away from built up areas.
