L LPS New member Feb 1, 2025 #1 Hi all. The pin that comes with the plug for a 330b, when is that used, or not used? Thanks
Johnny Electron Administrator Staff member Feb 1, 2025 #2 It is used when NMEA 2000 bus termination is needed.
Sparky Wire It's expensive to let the smoke out. Staff member Feb 3, 2025 #3 It is helpful when you have a very long GPS cable that exceeds 6 meters. Using the termination pin (Resistor ON) can let that run be part of the backbone so it can be extended beyond normal drop lengths.
