No wind after multiplexer removed
Hello
Finally sorted out the VX2 no position issue which turned out to be the multiplexer. Tech removed the multiplexer out of the circuit and simplified the layout. I have position and COG SOC in the Dbox.
Issue I have no is no wind on the VX2 display. Shows fine on the F1-30 units.
I check the port and MVW is set to "on" at the plotter. C82 on the FI-30 is set to MWD.
Does anyone know of any other settings I need to check?
David
David,
Can you find out what is exactly (Wind, Compass, Log, Depth, Etc.) wired/configured into the FI-3005 Server..?
- Deep Blue
